I don't know if it's related but my problem seemed to start after I replaced the cat and the rest of the exhaust behind it. The engine would randomly die in traffic, I just assumed I killed it as I had my earbuds in alot at the time until afew days later it quit and wouldn't start back up for several minutes/tries/gas pedal taps. Finally started and limped back home with it dying several times along the way. Havn't been able to start it since.
I've replaced the spark plugs, wires, cap, rotor, cleaned out distributor with brake cleaner. Replaced the 3 main fusable links on the drivers side with cartridges pink green pink. Replaced ignition coil with a new MSD one, the battery is good. I don't know if I'm doing this test correctly but when I hold the wire from the ignition coil to the distributor up to the chassis and crank it I get no spark.
What should I check next? I'm learning as I go and don't know anything about checking fuses. Daisy has served me faithfully for 7 years and this is the first time shes broke down without an obvious fix. :?
