91 fest with miss?
  • 91 fest with miss?
    got a 91 fest efi 5speed just changed fuel pump n filter, coil,cap,rotor,wires and plugs. and these parts havent fixed the wierd miss it has. it runs fine when its cold revs up nice and everything, for about 5 minutes then it begins to break up and pop. almost like sumthing is breaking down when it gets warm.it only does it while driving the car, idles perfect all the time. anyone with a good idea bout this problem is appreciated.
    Possibly an O2 sensor?
    2002 Ford Mustang GT Mineral Grey 5 spd
    1996 Ford Explorer XLT AWD White POS
    1992 Ford Festiva GL Metallic Blue 5 spd
      Kinda sounds like moisture in the dizzy. Or maybe the IAC. Now I'm just guessing...
      Going old school...
        look for a vac leak when warm, and cracks around the air tube after the VAF.
          Another thing that kicks in when the engine warms up is the ignition control module.
            ^ on all cars, the ign modual is ALWAYS active (cold, warm, doesn't matter). common guy, keep it straight.
