Power steering pulley
  • Power steering pulley
    Ok i got a festy with power steering on it everything is there the rack the powersteering pump with the pulley on it im missing the pulley on the engine for the actual power steering wondering if anyone has one ? And or possibly the bolts that hold it on ? Where does it attach the crank im assuming right? Car never had it since i just got it i have no clue every festy i had had now power steering seems kinda pointless to hook up but if cheap enough ill hook it up
    Lucky!!!!
    1991 blue L, 5 speed.
    1988 red L-plus-all stock.
      Whats so lucky ? I dont have the pulley to make it work lmao im not feeling lucky . Lmao
        Power steering is a really rare option on the festiva! I think it uses the same secondary crank pulley the a/c compressor does.
        -Zack
          Ok heres the skinny , the ac compressor is there seized up im tossing the ac stuff out , all i need is the crank pulley then ,this is on the festy i found with 72000 in the getto of down town detroit , im just wonderin if its even worth it to try to fix it u know if i had the missi g pulley i could get a shorty belt n eliminate the ac n just try the power steering
            Short belt might still be possible because the ps pump should have a tensioning bolt on it. I'll take that a/c stuff off your hands, not to mention I'd like to see the mysterious power steering set up with my own two eyes!
            -Zack
              Ill take a pic of the power steering stuff tomorrow or the next day i really hope i can locate a pulley n stuff for it to make it work
                I have an a/c pulley available if it is the same thing.
                  There were two differnt sets of pullies. One was for a serpentine belt, and the other was for a V-belt. When I put the V-belt on mine, I bought a power steering V-belt pulley off of a first generation Mazda 929. There was no need to mill out the holes. You can read about it my old power steering thread. In Germany, a lot of Kia Prides had the power steering option. This was the proper belt size to install with my V-belt crank, A/C. P/S combo.
                  Theis is what my final setup looks like.
                    I have no chance of finding this mazada 929 here in detroit its a unheard of deal ive called everywhere
                      I bought just the pulley off of eBay. You will have to buy the entire pump for $30 + shipping and then have the pulley machined to fit. But it will work.
                        I added tags to your original 08 thread, I liked the read, very informative. I think we should all start using tags on important threads, it help when you use the search lol..
                        The pulley looks like the one on my 5th gen 626.. I have no idea if they're even close tho..
                        2008 Kia Rio- new beater
                        1993 Festiva- Fiona, DD
                        1997 Aspire- Babyspire, DD
                        1994 Aspire - Project Kiazord
                        1994 Aspire- Crustyspire, RIP
