Login or Sign Up
Logging in...
Remember me
Log in
Forgot password or user name?
or
Sign Up
Log in with
Forums
Today's Posts
Member List
Calendar
Forum
Maintenance
Repair Help Forum
Welcome, Guest! Want to see the rest of our forum? Then
sign up
today.
93 festiva surges / jerks when driving.
Posts
Latest Activity
Photos
Search
Page
of
2
Filter
Time
All Time
Today
Last Week
Last Month
Show
All
Discussions only
Photos only
Videos only
Links only
Polls only
Events only
Filtered by:
Previous
1
2
template
Next
RhodeStiva
replied
05-26-2012, 09:40 AM
thanks
runs great it was the coil . you guys are awesome on here.
Originally posted by
FestYboy
then go read what i posted in your other thread about this.
Post Comment
Cancel
FestYboy
replied
05-21-2012, 02:14 PM
Post Comment
Cancel
RhodeStiva
replied
05-21-2012, 07:42 AM
The engine shakes a little on idle . But yea its only in gear that it does it
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
Post Comment
Cancel
RhodeStiva
replied
05-21-2012, 07:35 AM
Yes
Post Comment
Cancel
WmWatt
replied
05-21-2012, 07:30 AM
So it runs fine idling at high revs? It only misbehaves under load?
You might put the font end up on stands, start the engine, and put it in gear.
WmWatt
05-21-2012, 07:38 AM
Post Comment
Cancel
RhodeStiva
replied
05-21-2012, 05:30 AM
What could it be? any suggestions
Post Comment
Cancel
FestYboy
replied
05-20-2012, 10:05 PM
mattrhodes850
No. coil is good i think the fuel filter.
fuel filter won't affect a low speed load based hesitation unless it's so clogged that it's affecting rate of flow (unlikely).
Post Comment
Cancel
RhodeStiva
replied
05-20-2012, 09:55 PM
Mine is doin the same been help.
Post Comment
Cancel
RhodeStiva
replied
04-28-2012, 07:33 AM
Post Comment
Cancel
denguy
replied
04-28-2012, 07:07 AM
Coil?
Post Comment
Cancel
RhodeStiva
replied
04-27-2012, 09:01 PM
Mine does the same thing only in first gear and if you change gears to early i think ir might be fuel filter. I knocked the guts out of my catalytic convertor and it helped a little there was a clog in it.
Post Comment
Cancel
Flyin4stroke
replied
04-16-2012, 02:32 PM
No carbs on 93....
Post Comment
Cancel
91mcnasty
replied
04-16-2012, 12:13 PM
Mine did the same an the carb is bad.
Post Comment
Cancel
cway1319
replied
04-16-2012, 11:48 AM
U said its been off the road a while? Bad gas? Maybe some "heat" or other treatment
Post Comment
Cancel
Movin
replied
04-16-2012, 10:55 AM
Make sure the VAF is not sticky and that the connection from it
to the throttle body is air tight and has no cracks that open
up when the motor rocks.
Post Comment
Cancel
Previous
1
2
template
Next
Yes
No
OK
OK
Cancel
