I finished the Aspire swap, and got it aligned. As a summary, this is what has changed:
New Festiva LCA
New Festiva Inner TRE
New Aspire outer TRE
Aspire Swaybar
Aspire hub assembly, brakes
Aspire struts (front)
Now, the issue is whenever I accelerate. The steering wheel shifts to the right. It won't shift back until I let off. It's very sudden when it does, and doesn't feel like normal torque steer; it's very excessive. In 1st/2nd gear, it's almost impossible to hold the car straight at WOT. The problem is still there at higher speeds, even up to 95-100mph. Feels like the car is tilting, and then it falls back down.
I changed to Aspire front struts, and the problem was still there. While doing that, I checked over everything and it all seems solid. Nothing is loose, and there's no play in the steering. Also, the issue started when I did the front swap, the rear beam had been on the car for a week with no ill effects.
I just don't really know where to start. Any ideas?
New Festiva LCA
Aspire Swaybar
