Didn't have knock sensor plugged in.
  • Didn't have knock sensor plugged in.
    I was just pulling my motor today and noticed that the knock sensor was not hooked up to the harness. What ill effects could this have caused?
    Maybe it's why motor is about dead.
    91 Festiva BP Autocross/Track/Rallycross hopeful
    14 C7 Z51
    knock box retards timing when it senses pre-det. pre-det WILL damage rings and valves if left unchecked.
      Are we talking about the black box?
      1989 Ford Mustang GT 5.slow
      1996 Ford F-150
        ^^without the knock box, it wouldn't run, I'm sure he's talking about the knock sensor on the back of the block beside the oil pressure sensor
          Yah I was talking about the sensor. The box was plugged in. Does anyone know how much timing the box will pull? I think I read that it will only pull one degree. How much correcting can the box acually do?
          With the n/a block and tbird turbo im worried about too much boost and higher compression.
          I shall see what happened to my motor when Im done swapping engines.
          14 C7 Z51
            That's what I was thinking.
            1996 Ford F-150
              that box can pull up to 10* of advance.
                Thank you.
                14 C7 Z51
