Need front end toe-in/out alignment specs
  • Need front end toe-in/out alignment specs
    After replacing a failing tie rod ball joint, I need to re-set my toe-in/out.
    The only thing search turns up is ".02-.26" (which I presume is in inches) but doesn't say whether this is "in" or "out." Haynes doesn't have any toe-in/out specs.
    I'm going to do this like I used to do on my Fiat -- precisely cut to length of piece of rod and hold it up at the 3 o'clock and 9 o'clock position of the wheel rims.
    Can somebody tell me:
    1. Should I should have the wheels pointed up to .26" IN or up to .26" OUT?
    2. Is it OK to do the alignment with the front wheels off the ground?
    88L black, dailydriver
    88LX silver a/c, dailydriver
    4 88/89 disassembled
    91L green
    91GL aqua pwrsteer
    92GL red a/c reardmg
    1952 Cessna170B floatplane
    front alignment specs
    This is from the Ford Factory Service manual, front Toe-In mm (in) 0.5-6.5 (0.02-0.26) . If there is anything else i'll try to find it if you want to email me. I could scan in some pages if that'll help.
      toe-in
      Thanks! 1/4" toe-IN on 12" wheels seems like a lot. I'll try to hit the middle of that range with about 1/8".
      91L green
      91GL aqua pwrsteer
