How do you get front rotors apart or off to change them? :?
front rotors
Rotors
you have to take the complete Knuckle off the car, This means undo the big nut, undo the strut, tie rod and ball joint, take the complete knuckle put it in a big vice and pound the crap out of the inner bearing untill the thing pops out. then you have to undo the 4 bolt that hold the rotor on. Regrease your bearings, or buy new ones, put your new rotor on and go back to the vice and pound the thing back together carefully so you have the correct preload on the bearings. Or you could take the car in to a shop that has a fixed price for brake jobs and let them do the work.1996 Aspire, 2DR 5SPD 185 60 14, Aluminum rims, Mild Stereo system, some neon tubes, 185 000 km not a speck of rust runs like a champ
B8-ME Swap COMPLETED.
