Rack Question or 3
  • Rack Question or 3
    What lubricate is in a rack? Oil, grease, none? When replacing tie rod boot(bellow), what do You do to clean and Lubricate?
    I was going to spray with brake cleaner and then lather with wheel bearing grease. Then put new boots on. Good, bad?
    Thanks in advance!
    ENFORCER - Midwest Festiva Inc., Iowa
    #2 .....Cheesehead
    #3 '91 White - Donor Car
    #4 .....Montana Project
    SOLD----Levistiva for $1500
    Bought her back for $450
    I'm assuming it's just regular grease in there, but I honestly don't know for sure
      FB71, suggested lithium grease to me when I inquired about the same thing.
      As he did not find a specified lubricant for the rack.
      I think any high quality lubricant will be fine, considering what it has been operating under (no boots and/or lubricant).
        Good point! Lithium it'll be after cleaning.
        #2 .....Cheesehead
          It's not going to heat up like the bearings so you would not need the high temperature bearing grease. Ordinary chassis lube grease should do.
            I used marine wheel bearing grease.
              I sprayed with lithium grease.
              I have learned so much during this suspension rebuild. As many know, I have done halfshaft writeups and do most Festy repairs and swaps myself. Somewhere in the beginning of my rollerskate addiction, I acquired a bad habit, whether through misinformation or just stupidity on my part. I always thought that when the inner tie rod went bad, it required a rack rebuild. I would always just replace the rack with a good one with good inner tie rods and boots. Man, was I ever wrong, causing me a lot of unnecessary work.
              Cool thing is I'm learning this bit of info on Levistiva, which I sold a couple weeks ago, and getting paid for the labor! Nice!
              #2 .....Cheesehead
                I used Wheel Bearing grease. Ran the rack all the way out one way, cleaned it with brake clean and a rag, then the other side. Then back to pack with grease, mounded it up and slowly moved the rack inboard, once in I put the inner boot on and secured with zip ties. Flipped it over (mounted in vise) and did the same to the other side.
