too much oil
  • too much oil
    I had the same problem with my lawnmower last summer. Going across slopes in one direction, it spewed out house-sized clouds of grey smoke. I drained out some of the oil and the problem went away.
    I once had a Fiat that smoked badly on startup. I tracked it down to the #3 cylinder, which fouled its plug every 100 miles. For a long time, I carried around a box of plus and stopped regularly on the side of the road to change #3. Eventually, I found a cracked valve guide that was letting oil drip down into the #3 cylinder.
    88L black, dailydriver
    88LX silver a/c, dailydriver
    4 88/89 disassembled
    91L green
    91GL aqua pwrsteer
    92GL red a/c reardmg
    1952 Cessna170B floatplane
