Rolls when in gear why?
  • Rolls when in gear why?
    Recently bought an 88 stiva 21000 original miles, 4speed it has been hit light in the front and been sitting since 1990. There was no contact damage to the engine or trans mostly cosmetic and radiator was damaged. When put in any gear including reverse the car stills rolls like it's in neutral any suggestions as to why this is happening would be helpful.
    Clutch/diff damaged, either during the accident, or due to misuse by the owner. An extremely loose engine can allow the vehicle to roll as well.
    Is it 21k or 210k?
      Only 21k I also bought a rollover from the same guy an 89 fi model with 2440 original miles crazy finds huh!
        Have you attempted to drive the one that rolls in gear? Be extremely careful if you do.. if the diff is broken enough, it may force the pin or a chunk of gear through the housing and ruin the transmission completely.
          No I haven't even started the car yet only started to fix the collision but there is no obvious damage to motor or tranny the car was hit high in the front so I couldn't see how damage from the wreck could have happened. And with such low miles wouldn't think any thing could of been wrong with the clutch
            It has been sitting for 20years could moisture have rusted anything on the clutch to make this happen?
              20 years sitting? put a little oil in the cylinders and run it a bit, compression
              should come back.
                Yeah, there's a pretty good chance its' got stuck rings and isn't holding/making compression. I didn't think about that LOL.
                  if the thing is stuck that bad then the engine would seize and it wouldn't roll at all I'd say.
                  Facebook Me!
                    Rings stuck to the piston grooves, not stuck to the cylinders.
                      rust will cause a clutch to stick in place too, be it engaged or disengaged.
                        Probably nothing stuck, just dry. Oil it and race it!!
                          If there is no resistance at all, something is broke. If there is some resistance, motor has issues.
                            Originally posted by CraigsT8Dstiva View Post
                            ...it has been hit light in the front and been sitting since 1990. There was no contact damage to the engine or trans mostly cosmetic and radiator was damaged. When put in any gear including reverse the car stills rolls like it's in neutral any suggestions as to why this is happening would be helpful.
                            No I haven't even started the car yet...but there is no obvious damage to motor or tranny the car was hit high in the front so I couldn't see how damage from the wreck could have happened.
                            Well there's the problem. Yes, there is damage, and the guy who sold it to you knows too. That's just a little something for you to remember for the future.
                            Visualize this: If the car got hit while parked in gear, it could have busted one or both of the cv axles joints. You'd get the sensation of it not being in gear. Another thing that happens is, tow truck companies are notorious for towing cars from the wrong end when it's blocking something in and they can't get to the correct end of the car. That tends to damage a lot of stuff that doesn't get found out till much later. Not always 22 years, but I believe you get my point.
                              Make sure both axles are in tight to the transmission. If one side has popped out, that will let it roll in gear.
                              You gonna race that thing?
