think i got the vacuum lines correct,not sure.set idle and time and it purred while sitting then hooked the vacuum lines back to distribitor and the idle fell real low and tryed to drive it and it dies when you are coming to a stop and it jerks while your driving down the road.honestly this car is driving me insane.please help and if anyone has a carb car with the stock b3 close to morristown tn 37814 i'd be will to pay just to use your car to go by,also if anyone has good pics showing how the vacuum ,lines run that would be great any and all help is accepted and appreciated thanks.
still need help with my 89 festiva
Not a bad idea. The car is my daughters. Runs great but isn't tagged yet. Since his isn't running well....
Blue, you are welcome to bring it over if you can!Contact me for information about Festiva Madness!
I am at the parts store now, will get the pics when I get home, check the album by 9:30- 10:00 PM EST. Those may be hard to get though!Contact me for information about Festiva Madness!
Chamber A on top of the vacuum advance should give you 10 deg of additional advance
over your base setting when you apply vacuum to it. It should hold vacuum as well
and not leak.
Chamber B next to the cap should give an additional 14 deg of advance and also
should hold vacuum.
When you test these one at a time the engine idle should speed up and smooth out.
I suspect you may have a worn breaker plate causing the pick-up to have excessive
clearance...only when you are advancing it or driving it with it hooked up.
Try driving it with the advance unhooked, I bet it drives better, but will lack the
power it should have.
A reman distributor is probably your best bet. You could get a new breaker plate
and pick-up but they are harder to find and you still have old parts in the disty.
You could get a guaranteed good JY unit..
You are doing great !Reflex paint by Langeman...Lifted...Tow Rig
OK, I added some pics. The lines are NOT precise, just a general pointer, you have to follow on your own. Drew them on my phone as I was looking at it.
The first I have noted in the album, is from a different car that has a couple of the hoses still in place, with the engine out.
Hope it helps!Contact me for information about Festiva Madness!
yeah, they're the same.
sry for not getting back to you sooner BTWTrees aren't kind to me...
