MAF replacement/substitute?
  • MAF replacement/substitute?
    1995 Aspire 4dr 1.3L manual.
    I have a code 8 & I checked the signal coming from the MAF to confirm its bad. Parts store refurb units are $200!
    Is there a cheaper or used source from a different car that would work? even if that requires modifying/adapting the setup.
    I suppose I'll start with junk yards for the stocker.... or a suitable substitue if there is such a thing.
    '95 Aspire 5spd
    Did you try cleaning it yet?
    Spray the little wire inside with ELECTRICAL CONTACT CLEANER.
    Do not touch it. No q-tips. No rubbing alcohol, windex, carb cleaner, brake cleaner, etc.
    Use ELECTRICAL CONTACT CLEANER!
    You can get it at most auto part stores for about $4.
    www.dantheoilman.com
    Go ahead and ask me why
      yep, already tried that. one of the 1st things I did.
      '95 Aspire 5spd
