My Instrument Cluster has been working great for years, till yesterday when I replaced my "cluster peanut bulbs" to red, it looks great and all when I installed it. Except for 3 things!
The speedo stopped working even if I connected it properly, the gauges don't work and the warning lights all stopped working. JEEZ! I had everything on properly (I think). My speedo is actually connected and when I take off the speedo's cap thingy, and leave it loose the speedometer works, but jerks up and down a bit. When I put that cap thingy on, it doesn't work or gets stuck if I get lucky when I get it working.
My question is, How do I properly reinstall the speedo-cable? Do you guys have any advice on this? Also, is there a spray I can use to clean the contacts on the cluster that won't short-circuit it also?
Thanks a lot!
The speedo stopped working even if I connected it properly, the gauges don't work and the warning lights all stopped working. JEEZ! I had everything on properly (I think). My speedo is actually connected and when I take off the speedo's cap thingy, and leave it loose the speedometer works, but jerks up and down a bit. When I put that cap thingy on, it doesn't work or gets stuck if I get lucky when I get it working. My question is, How do I properly reinstall the speedo-cable? Do you guys have any advice on this? Also, is there a spray I can use to clean the contacts on the cluster that won't short-circuit it also?
Thanks a lot!
