If we have a BP swapped Festiva, do we use the Festiva or Escort GT timing procedures? I know the EGT we have to ground out the ten plug to set timing, same with an Aspire, but not sure about a Festiva.
Escort GT and Festiva ignition timing procedures
Depends on harness used. Festiva has a single wire plug near the master cylinder.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
If you don't ground the plug, you aren't getting it set right. Grounding that plug tells the ECM to set "base timing" without compensating for load etc.Originally posted by BEASTS'TIVA View Posti just connect vacuum gauge to intake and turn distributor. once gauge is highest, then lock it down.
