So I'm getting my festiva ready do daily use. Went to the garage to check the engine. Started easy enough, but makes a noise kind of like a power steering pump thats low on fluid (NOTE: I don't have power steering) and as it warms up, the idle gets real low. According to the tach its idling at about 300 - 400 rpm. Any ideas? Is this common?
Engine noise and low idle.
EFI or carb?Originally posted by Cheapo View PostSo I'm getting my festiva ready do daily use. Went to the garage to check the engine. Started easy enough, but makes a noise kind of like a power steering pump thats low on fluid (NOTE: I don't have power steering) and as it warms up, the idle gets real low. According to the tach its idling at about 300 - 400 rpm. Any ideas? Is this common?
a sound like that is usually attributed to the ALT.
take off your belt and see if the idle and noise changes.
also wiggle and spin the WP and ALT pullies by hand.
report back with results.Trees aren't kind to me...
Haven't checked yet but its most likely EFI. Its a 1990Originally posted by georgeb View PostEFI or carb?
I'll do that tomorrow. I hope its just the alt.Originally posted by FestYboy View Posta sound like that is usually attributed to the ALT.
