I am ready to remove the motor for the B6 swap, and I hit a snag.
The pass side axle is stuck in the hub.
I had this all apart last summer. Replaced everything, except the axles. Had no problems removing axles/hub then.
The driver side axle pushed in, with a push of my thumb, after removing axle nut, earlier today.
I have beat on the pass side axle with a hammer and a 1 inch aluminum bar, and even gave it a few whacks with my 12 lb sledge! No movement.
Is there anything I can do to get this axle to move?
Or I am I to keep beating on the poor thing till its gives up?
The offending hub:
The offending hub:
