hey, im working on an stock festiva (not mine, lol...) and the meter fuse keeps on blowing after you start the engine... any ideas?
meter fuse keeps on blowing?
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
no one in the last year has touched it other than me lol... and i have never done anything to the wiring in it...
you've got a short (but you know that). time to trace on the unpowered side of the fuse block. take out the fuse, put key in "on" position and probe both sides of the fuse terminal. the side WITHOUT power is the one you want.Trees aren't kind to me...
Look for that plug right at the alternator to see if it's not staying connected or may have come loose and touches on and off, OR for the wires (red and brown) within it to be coming out of their metal ends.
A surge of power on that line at ANY point in it from a quick "make-break" situation will blow that fuse. Otherwise, Festyboy is right, look for the short and that may be at the "charge light" bulb in the instrument cluster, or the alternator itself.
Last edited by Movin; 05-06-2012, 06:05 PM.Reflex paint by Langeman...Lifted...Tow Rig
Iceracer is right. The METER fuse is also involved in the charge warning indicator circuit. Black/red wire between alt and light, black/yellow between light and fuse. Indicator light has 100 ohm resistor if that means anything ('92 wiring manual).
