My Festiva has a major electrical problem.
Ok so since my car is at my farm and I am not there for a week my car sits. I see it once a week, and every week I leave the battery connected to the car.
Stuff appears on the battery (corrosion?) and the car drains the battery. I am not sure what is causing the drain. I am pretty sure it is a bad connection somewhere because I had a similar problem and I juggled the positive cable and it would work, but now it seems to be doing it again and I am pretty sure that the positive cable is not the issue.
I know for a fact that I will need a new fusible linkage box soon (it has problems), and I will replace the positive cable.
Do you think that (box and cable) are the problems or there might be other problems, I also know that the coil might be bad - not sure.
I will upload a video on Youtube of what is happening, later today.
Thanks
Thanks
