Dealer or factory AC
  • Dealer or factory AC
    Im going to put an AC system in my car and i found 2 different types.
    Just to confirm, this is dealer installed correct? It looks different than any other aircon system i have seen.
    The reason i ask is that i want a factory AC.
    06 Jeep Cherokee Overland
    95 Aspire (sold)
    That doesn't even look dealer installed. It looks more like aftermarket.
    93 GL modyfied!!!
    :fish:
      It looked like a mess... Ok, there was another one there with pressure still in the tubes. I guess ill be pulling that one.
      95 Aspire (sold)
        I have a dealer installed unit, & it looks nothing like that. I'll take pics tomarrow.
        '93 Green L - ' Tiva
          The engine looked like it needed some help before use as well..
            yeah stay away from that crap haha, looks like aftermarket junk!
            -Josh R
              Amazing, thank you, 3 of the 4 festivas there had air con, 2 looked the same, one had this mess.
              95 Aspire (sold)
                That kind of expansion valve is wasteful but performs really well. Probably should
                have been left on the Cadillac. It may have a better condenser and evaporator than the
                stock or dealer added cars. If the fittings are the same you can mix and match to get
                the best components from each car. Be absolutely certain that the internals are clean.
                  I pushed the little valve thing and air came out so i assume that they are all still under pressure.
                  95 Aspire (sold)
                    If the system still has pressure it may be okay. If the compressor seizes it will
                    contaminate the entire system with metal fragments. To check the compressor
                    for dirty failure turn the compressor clutch hub. If it spins freely then yes, scavenge
                    parts!!
                    The clutch hub is in front of the belt pulley and should have some resistance but not
                    spin free like the pulley will just behind the hub.
                      parts!!
                      Thanks for the advice!
                      95 Aspire (sold)
                        Happy pickens!!
                          Ok, got the pics of my dealer installed unit.
                            Got 1 more. Don't know if you can see the drier, its under the intake tube near the VAF.
                              Evac n charged yet?
