Well, before I replaced my right side front wheel bearing, changed my passenger side CV axle due to a torn boot, and replaced my tie rod end (the other side will follow soon), I kept hearing a constant grinding sound and a clunking sound when I would go over bumps and make sharp turns throwing the car's weight on the passenger side. Well, I figured the bearing was bad so I replaced it, so no more grinding/groaning sound
However, it does still "clunk" when going over speed bumps and such. Any ideas? My ball joint looked okay, but I don't really know much about Festiva ball joints, given the fact that the ball joint kinda doubles as a control arm. My springs are pretty rusty though, so could that make the noise?
Also, something I should mention: The manual said to remove the sway/stabilizer bar bracket (the one that holds the sway bar bushing). Well, there are two 14mm nuts under there that hold it on. Unfortunately, no amount of Liquid Wrench or PB blaster and soaking days could loosen the second nut, and it got rounded off. So I got the brilliant idea to remove the three nuts on the bracket that the first two-nut bracket is attached to. The one that mounts on the frame. Well, one came off okay, but the other two twisted off, taking the exposed bolts with it :eeeeeek:. So only one bolt is holding it on.
That might be where part of the sound is coming from, but it was making clunking noises going over speed bumps before that so...
I assume the only fix for that is to take a drill and drill the remainder of those bolts out and run some similar fitting bolts upward into the frame instead of downward, coming out of the frame due to the fact that I can't really access that part.
What do you guys think?
