I recently replaced the water pump in my Festiva (B6) and once I had everything back together a regular squeak developed that varied with engine speed and showed up only after the engine was warmed up. I figured that perhaps I had a bad water pump so I disconnected both the alternator belt and the A/C belt and the noise is still there. I then replaced the timing belt and tensioner with no change in the squeak.
The squeak starts once the engine has warmed up a bit and isn't there on initial start up and seems to be coming from the bottom end rather than the top.
Am I correct in assuming it's time to replace the oil pump?
Thanks
Thanks
