what brand, part #, parts store for A/C dryer?
  • what brand, part #, parts store for A/C dryer?
    I got one from NAPA, part # 208355, also has 33484 on there, but the filter itself says Atco 7-4135 and XH-7.
    It's too long, had a bracket tack welded to it which I bent to fit into my bracket and now I find out that its threads are too big.
    Don't know which festiva has AC, you have 4 ? but there are 4 different ones, dealer installed or
    factory, and both those with or without PS.
      This one is factory installed without P/S, (black car). I have a factory system I'm putting in the red car, the white car also has a factory system, the blue car has P/S with an aftermarket (I believe) system.
      I say they're factory because they all look the same.
          Went to O'Reilly's at lunch, had the same one with the bracket on it, $13 more than Napa.
            Am hoping someone has a good part number that maybe I can cross reference.
            The bracketed one has 3/8" fittings which are supposed to be uber common.
              Luckily, the NAPA I bought the wrong one from still believes in cross reference catalogs.
              Turns out they're 14mm fittings, found one for a one year only '92 Honda car that was an inch shorter, but should work. Only 4 in the US (now 3), happens one was in the warehouse at OKC.
                What is the length of the one you bought? I bought one from Texas and the diameter is too small.
                  I can check our parts car if you like. But I am not sure how to post pics to the theards yet. I will text you some pics if you like just pm me for my number.
                    stock one was 7.5", this one is 6.5" and 2.5" diameter. I think it was for a '92 Prelude.
                      http://www.bwbronze.com/festiva/drier.jpg
                      Here's a pic of the one UAC sent me for a Festiva. What's unusual is the fact that the part number on the box differs from the part number on the drier. Slow moving inventory?
