Hi guys i got the bones brother in my shop right now pulled the head 73000 miles on it , head gasket is new but the guy who did it put everybolt on this thing wrong , heres my question .... How common is it to get a cracked head as i dont see anything visable wrong on the head ? Hit me up guys
Head crack how common ??
Frank here (8 and vandyke) I think you were over to get something off me. anyway, nice shot of the gasket! look real close between the intake and exhaust valves. In my experience (and I can't find cracks in heads either) when I don't see a crack my machine shop guy never fails to find one. Also, don't forget to look very close at the cylinder walls. If the engine ever froze it's very possible to have a crack in a cylinder (you would probably have water in the block then however)Originally posted by runner406 View PostHi guys i got the bones brother in my shop right now pulled the head 73000 miles on it , head gasket is new but the guy who did it put everybolt on this thing wrong , heres my question .... How common is it to get a cracked head as i dont see anything visable wrong on the head ? Hit me up guys
good luck.
Chase the head bolt holes, and clean the head bolts. If any are stretched, replace them.
A little copper kote would go a long way to adhere these surfaces. I like a little liquid
Teflon on the bolt threads. Then proceed!!
Yep frank i got a few small parts from you bro , i will probably take the head to fairway engine in utica and let him look it over before i re install it even tho im pretty sure its ok better safe than sorry i checked the block really close looks good
x2Originally posted by NovaSS View Postcheck for a warped head2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
They can test the head. I would have it surfaced as well. Water in the oil is not a good thing. It tends to wipe bearings out pretty quickly.Brian
