I have factory air, but i only have one relay and the numbers are, ND 2070 send me a pm. thanks. wait i read this wrong, give me a minute i'll get the correct #'s for ya
It would be helpful to find a wiring diagram but that might not be possible because of all the variances with AC systems. If you could, it might just be as easy as installing two automotive DPST relays, $4 each with wired pigtail sockets... If you know much about electronics, maybe you could trace the wires to find power, ground, switches and loads.
-Zack
it closely matches the specs of the original, its not exact but close
Datasheets CA Relays
Product Photos CA SERIES
Other Related Documents General Appl Guidelines
Standard Package 20
Category Relays
Family Power, Over 2 Amps
Series CA
Relay Type Automotive
Coil Type Non Latching
Coil Current 150mA
Coil Voltage 12VDC
Contact Form SPST-NO (1 Form A)
Contact Rating (Current) 30A
Switching Voltage 16VDC - Max
Turn On Voltage (Max) 8 VDC
Turn Off Voltage (Min) 0.6 VDC
Features -
Mounting Type Chassis Mount
Termination Style Plug In
Packaging Tray
Contact Material Silver Alloy, Cadmium Free
Operate Time 10ms
Release Time 10ms
Coil Power 1.8 W
Coil Resistance 80 Ohms
Operating Temperature -30°C ~ 80°C
06 Jeep Cherokee Overland
95 Aspire (sold)
