My Aspire was in a wreck from PO. The left side has a Festy axle & the engine mount is custom. I had to relocate the engine about 3/4" @ the RH mount.(In order to get the motor "squared")The entire front end is basically new excluding the rack. I'm still getting a LH vibration into the steering wheel. It never happens on smooth pavemant. Only occurs going up or down a grade. It comes in @ 65-75 and will stay till you slow down past 65. Im running @ 1/32" of total toe out,measured via my Red Neck gauge. Also tried new tires,it helped but didnt cure. My real reason for telling you all this... If my LH knuckle has NEG Camber.Instead of POS Camber.Could this be the cause of the vibration? Like perhaps the Caster is pushed back to zero.And the tire is "Fluttering"?
Thx-
![Confused](https://fordfestiva.com/forums/core/images/smilies//confused.gif)
