Hi all,
I was driving and my festy died as soon as i hit the clutch pedal while shifting into 3rd. Here are it's symptoms :
It sounds different when it tries to crank, i wish i could describe how, but it's just off. When the key is in the on position, there is an engine component that is making a constant fast clicking noise that almost sounds like a cooking timer, but i'm not sure what it is. as your looking at the engine from the front of the car with the hood popped, it's located behind the far right fuel injector. It has an electrical connector and many various air hoses connected to it. It's blue around the sides and has a hex nut on top. I'm guessing it's the idle air control valve.
I tried the fuel pump reset button, checked the engine fuse from the interior fuse box, checked the spark plug wires.
