Someone else has seen this I know it. Hopefully!!!
1990 Festiva, Auto with AC & 74000 mile. Driving down the road 45ish @ 2200rpm the engine will start too cut out,(would stall if I let it) if you feather the gas a little it will stay running and as long as you keep the rpm's up it appears to be OK. Engine is not overheating (according to the dash temp gauge) and the cooling fan comes on and off as it has ever since I have owned the car
I have swapped known good working parts from my 1993.
VAF
TPS
I have replaced with new.
Plugs
Cap/Rotor
PCV
Air Cleaner
Fuel Filter
Now the weird. If I unplug the Radiator Fan Contol Switch and let the fan run all the time the issue goes away
Thanx
Richard
VAF
TPS
Plugs
Cap/Rotor
PCV
Air Cleaner
Fuel Filter
Thanx
Richard
Either a clogged cat , fuel filter or fuel pump sock,
