My car is a 90 EFI manual. Today I was driving home from work, and when I got off the highway and stopped at a red light it just died. It started up so i keep driving and it was running rough. Everytime i had to stop it would die. I did notice for the past week or so, that when I was stopped it would idle rough and only idle at around 600 rmps. it also sounded like I had a small exhaust leak but was not really loud. When I finally got home I popped the hood and I smelled something burning. I notice smoke coming from the catalyic converter where it connects to the down pipe from the engine. I also noticed that one of the hangers at the cat is not connected. (Broke Off)The temp gauge was in the normal zone so the temp never went up. Could my cat be clogged? I pulled my service records, I had some exhaust work done 12/02/09, but it the invoice doesn't show that the cat was replaced. Just muffler, connection pipe, and gaskets installed.So I don't know how old the cat is.Its weird because I just had the car inspected and it passed Emissions on 05-30-12. I need to know if anyone thinks my cat could be clogged or if there is something else wrong. I just tuned it up before inspection. New cap, rotor, plugs, pcv, and air filter.
I never had a cat clogged before so I need some advice to know if its the cat that could be the problem or is it something else.
sorry for the long post.
They will pull the fuel rail back where you can see the injector tips and cycle
