Originally posted by kellen302
Engine Knocking Over 50mph, Surging Idle, White Smoke
1989 Festiva L worklog/photojournal: http://imgur.com/a/I4DV5
Every day it gets from point A to point B is a victory.
Don't panic yet, when the timing's too far advanced OR you have too much carbon buildup in the combustion chambers, you get knocking. The "too much" carbon situation makes the compression ratio go up is why you get knocking from that. It will also cause a slight to high overtemp situation as well. You can do a sea foam treatment to get rid of the carbon and you will sea results from the very first treatment, you may need a few (reads: one can does three treatments). You need a timing light to check/set the timing, but until you do the sea foam treatment, just use a couple of tanks of midgrade to stop the knocking somewhat (see how that works) Then while you get the carbon under control, you'll have time to figure out who can check the timing for you. And if it turns out to be just excessive carbon, you will have gotten that under control and you probably won't have to "time" it in the end.
The "idle surging" sounds like a vaccum line broken or off and/or a tps going bad. All inexpensive things to fix, mainly because you can do most of them yourself.
The brake thing is a sticking caliper, when you replace them, make sure you get the lifetime replacement deal like Advance or AutoZone offers with there's
Parking on dirt, gravel, or grass really, REALLY accelerates caliper deterioration as well as anything else on a car that can rust.Last edited by iceracerdude; 06-08-2012, 06:04 PM.
Originally posted by iceracerdude View PostThe "idle surging" sounds like a vaccum line broken or off and/or a tps going bad.1989 Festiva L worklog/photojournal: http://imgur.com/a/I4DV5
Just think of as you would any good tool except that if you buy it "used, good condition" from amazon.com for $1.02 with $3.99 shipping, it will be the most cost effective tool you've ever owned! This link may take you right there: http://www.amazon.com/gp/offer-listi...condition=used
Originally posted by iceracerdude View PostJust think of as you would any good tool except that if you buy it "used, good condition" from amazon.com for $1.02 with $3.99 shipping, it will be the most cost effective tool you've ever owned! This link may take you right there: http://www.amazon.com/gp/offer-listi...condition=used
Well I've got a much more manageable problem now, but a problem like the rotors/hubs/calipers/bearings/etc... I'll let someone who has actually used a wrench for car work take a look at it sometime this three day weekend. Can anyone recommend a good mechanic or Festy enthusiast in South Florida?
And thanks for the help everyone! Sorry about the initial misinfo, AM driving mishaps before caffeine ingestion are tough for me to self-diagnose.1989 Festiva L worklog/photojournal: http://imgur.com/a/I4DV5
It's sounding to me like you have a seized caliper or a collapsed flex line, if your not too great with mechanical stuff, then taking it to a shop is probably a good idea to get properly diagnosed before replacing parts lol
Originally posted by 4wheeldevil View Posti told you to give costa a call
I'll call him tomorrow during the day when he's more likely to answer1989 Festiva L worklog/photojournal: http://imgur.com/a/I4DV5
