is there a way to ground out a sensor to keep the cooling fan running while the engine is on like i did in the past with another car model?
keeping fan running while key is turned
All you gotta do is un-plug the sensor on the T-stat housing, thats the fan switch
like i said before i am trying to avoid an overheating froblem during the summer when in the past another car fan of mine fan would not turn on in heavy traffic and toasted the head gasket. i went to the junkyard today and saw another aspire there which was like mine and i could not see a sensor on the water neck iis it on the bottom of the thermostat housing?? i just cant see it on my 1995 ford aspire in comparrison to my wtwo festivas in the past.. i got some relays from the junkyard today for spares
He probably read what you said, just saying if your fan is working properly there is no need to having it running 100% of the time. It takes a lot of overheating to warp a head, and there should be none if the fan and switch is working properly. If you're really worried you should run a switch inside the cabin to override any relays or sensors and turn the fan on whenever you please, just not all the time.
