I'm going to buy some manual transaxle fluid today and change it, I don't think it has ever been done on my car (170,000 Kms). I have the Haynes manual, so I have a pretty good idea of what needs to be done, but I'm wondering if anyone has any tips or suggestions when doing it. Also, what fluid do you all use? In the Haynes book, it says to use MERCON automatic transmission fluid, regardless of whether or not the car is a standard or auto. What does this mean for me when I go and buy the stuff? Can I buy any old automatic tranny fluid? I'm 17 and I've never done this before, so I'm a little wary of the process!
Suggestions and tips are appreciated!
Aaron
Aaron
i used an old STP bottle w/ the botom cut off... was quite a pain. other than that very straight fwrd.
. When I first put on new studded winter tires my Festiva sounded like a Land Rover on retreads! Very noisy (at least until I wore my studs down...). I've packed the interior rear panels with insulation and am going to also pull the door panels off, as well as the panel on the hatch. I've already noticed a large difference simply by filling the rear panels with insulation.
