I'm running out of ideas on my 323, I just got done dropping in a fresh B6T, everything piece of electronics from the old motor was re-used, intake, injectors, knock sensor etc.
On a cold start up it'll idle fine, once it get to operating temp it'll just die
At first I thought maybe my timing belt was out a bit, checked it and all good, then I thought vacuum leak, just got done pulling the intake and re-sealing it, all vacuum lines are hooked up etc. I'm running out of ideas as to what to check for
Anyone else have any ideas??
