OK. I have a start/run/stall issue. Car will run for a few minutes and then cut out. It will not usually restart for awhile. If I jumper the fuel pump test connector it will start/run/stall but it will immediatly restart and continue the process of starting/stalling.
My question is, When jumping the fuel pump test connection does this bypass everything that would control the fuel pump (VAF and Relay)? I can only assume that my issue is fuel related since jumping the test connector improves the starting process but does not fix it. I cannot get it to run long enough to do a running fuel pressure test.
The filter was new a couple months ago and the pump was a swap from a car that has been parked for a couple years but was fine when parked.
I am at my wits end, I have replaced new
Plugs
Wires
Cap
Rotor
PCV
Air Cleaner
Cleaned Fusible link connections and replaced with new style links
And Swapped with assumed good
VAF
Fuel Pressure Regulator
TPS
IAC
MAP Sensor
Coil
Ingnition Module
Distributor
I have cleand all the grounds I can find in the engin bay, I just learned the fuel pump ground is on the inertia switch. I will clean that tonigh. I ordered a new pump/strainer and filter but it will take a few days to get here.. The only thing I have not changed (I think)is the coolant temp sensor) I am looking for any insight on what I am missing.
Thank for all the replies to previous posts.
Richard
Plugs
Wires
Cap
Rotor
PCV
Air Cleaner
VAF
TPS
IAC
MAP Sensor
Coil
Ingnition Module
Distributor
Richard
