Curious, Fluffy seemed kind of weak at low rpm's, and idle was a little
high on HC. My analyzer shows CO and O2 on fuel diagnostics as well
as other stuff but I don't care about that stuff right now. I knew HC was
high but did not know if it was tired valves and compression or fuel mix off.
By now I know the answer but the same knowledge is easy for all with
simple tools too. It took a minute or so but I put my long radio shack
leads on one of the HF $3.99 meters and rigged connections from the Bat
Neg to the meter and using a "bed of nails" lead end to tap the O2 line
I had a driving reading of my fuel mix from idle to wide open throttle
in the passing lane. This was funner than being stuck in the shop anyway.
It turns out my idle is too lean for low HC readings, and it does not start
to read normal rich-lean until cruise. It goes richer wide open. It also
showed a sluggish O2 so I will be replacing it soon!! Anyway, pics below
Perfect is 0.450 volts. Lower is lean.
