help--no head lights 100 miles from home
  • help--no head lights 100 miles from home
    92 efi 200 k---I'm stuck about 100 miles from home and have no head lights-everything else works---changed fuses 30-40-30 twice--lucky I had spares--need help as soon as possible--sitting in a parking lot (515) 803-9556
    Just some thoughts:
    1. Does the main fuse (MAIN) or the one for the headlights (HEAD) keep blowing?
    2. Does wiggling the light switch do anything?
    3. Bad headlight relay?
    4. Can the headlights be temporarily wired directly to the battery?
    5. Ground issue, or a short?
    6. Last resort: sleep in car until dawn, then drive home.
    EDIT: just talked to him; it's already fixed, he's on his way home! It was the relay, which he jumped to get the lights back.
      thanks to my Festiva family I am now on my way home to get something to eat, will explain when I get home which will be in 1.5 hours---thanks to Frestiva and to Tom in Mo
        what was the problem?
          I just now put it in my post as an edit, before you posted.
            That is way cool!!
              gotta love the festy family!!!
              1991 blue L, 5 speed.
              1988 red L-plus-all stock.
                We have lights
                Hello Friends i'm home, thanks to Freshtiva and Tominmo, thanks for the call tom.
                Fresh called and had his repair book in hand, the problem was the headlight relay had gone bad, so as he read through the book he found that we could jump some wires and have headlights, so thats what i did and all is good.
                Again Thanks friends for the help.
                  Way to go Markus and Tom!
                  Good to hear you're home Karl.
                  Dan
