91 Festiva emergency brake cable
  • 91 Festiva emergency brake cable
    Does anyone know where I can buy a replacement emergency brake cable part. I don't need the whole thing, just the cable that goes from about the center of the rear axle to the passenger side brake?
    Any help would be greatly appreciated,
    Boss88
    Look in your mcparts store "help!" Section for a brake cable kit. It comes with enough cable for either side and cable stops for ~$10.
    Sent from the bathroom via crapatalk.
    91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
    92 L 5sp "Red" RIP
    95 Grand Prix SE DD
    Wife's Stuff:
    89 L 5sp "Carby Car"
    97 Aspire auto "Pink Panther"
    Build Thread
    Spring 2013 IndyStiva:
    http://www.fordfestiva.com/forums/sh...eet-April-20th
      I know this thread is a year and a half old, but what is mcparts store? and how do I find it?
        "McParts" is a general reference to the chain auto parts stores. I.E. Autozone (autozoo), O Reilly's (Oh, really), Advance Auto, Pep Boys, etc.
          Unfortunately aside from universal parts that will require modifications to make work, this cable is only sold as a complete unit. I got mine from fourgreen (for a four-door kia pride) and it was a couple inches longer but nothing a slight change in routing didn't fix.
          Also make sure the linkage at the backing plates aren't frozen.
            I know I fixed the broken part of my ebrake cable using some galvanized steel cable from home depot and line clamps. I made sure to grease the hell out of all the friction points after.
            - Form should follow function...
              My Ebrake was gone at the rear axel along with the brake adjuster's.
              Found a festy in the junk yard that had all that intacked so I got the whole ebrake out of the junked one, greased it up, and put it in mine along with the brake adjester's.
              1993 Ford Festiva L blue 170,000 miles
              1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
              1995 Ford F150 XLT black 203,000 miles
              2002 Honda CRV silver 180,000 miles
              2003 Toyota Rav4 Sport black 94,000 miles
              2008 Sym Rv250 dark grey 30,000 miles. My scooter.
              1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
              Mike
                you can also get cable and fittings to make your own from motorcycle shops. might even think about running the cable through a plastic cable cover while you're at it.
                  great idea
                    Just use stainless cable and forget about the plastic sheathing. If they did this from the factory, nobody would ever buy another parking brake cable again.
