gonna be doing brakes soon and figured I'd do wheel bearings as well, a buddy around the corner has a press, its not as big as the machine shops have. does anyone know what size will work as far as press opening height required ??
what size press
hammer and a block of wood.... and 24mm socket with extentionTrees aren't kind to me...
I'm working on picking up a No. 3 arbor press. That would do the trick.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
I use a big bolt LARGE washers and an impact to zip it together, but you could use a wrench and ratchet.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
If you really want to use a hydraulic press any of the HF presses will have enough
height. Probably a foot throat would be comfortable minimum room. I believe the
shortest hydraulic one is about 26 inches. Some of the arbor presses could be a little
tight. Most any press should have enough width around it.Reflex paint by Langeman...Lifted...Tow Rig
thanx my man thats what i thought, just wanted to be sure,Originally posted by Movin View PostIf you really want to use a hydraulic press any of the HF presses will have enough
tight. Most any press should have enough width around it.He said a bad word :nono:
1990 Festiva
1987 F-250 diesel-powered
1984 Ironhead Chopper
1999 Ducati Monster
