where is the iac on '93
  • where is the iac on '93
    My 93 festiva tends to have a low idle whenever I stop the car. I sometimes have to rev it up a bit to stop it from stalling. I've been told it could be a dirty idle air control valve. I searched through my Haynes manual and it doesn't even mention an IAC valve. Does it have one? Or is it called something else in the manual? I would like to clean it (if the car has one) because that might help the low idle problem. I've never seen or cleaned one before, so if anyone has any tips on how to do it, I'd greatly appreciate your help.
    Also I've been reading a few threads and I've come across the acronym VAF. I'm not sure what that is, because it too is not mentioned in my Haynes manual. I even tried googling it and nothing came up. Is the VAF the same thing as a MAF?
    vaf = little flapper in air box
    maf = sensor in airbox ...
    both read the amount of air that enters the engine, festivas have the vaf
    vaf= vane air flow ... http://www.youtube.com/watch?v=Xkyfjo7spFc
    maf= mass air flow ... http://www.youtube.com/watch?v=sSuL58YEH-E
    1991 stiva.
      Iaccoca's should be on the back side of the intake on the driver side. Look for small coolant hoses going to it. But why don't you just bump up the idle screw 1/4 turn
      Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
        watermellon, have you adjusted the idle bleed screw on the throttle body? it's on the driver side of the TB under a little black rubber plug.
          1/4 turn clockwise or counter-clockwise to increase idle speed?
            Counter, and it will likely be more than a 1/4, but mark where you start from.
              thanks
