Here's the run down i have a 90 festiva with a b6d swap from a 91 capri. The swap has been completed for several months with no problems and getting around 38 mpg mixed driving. I don't drive her two hard but like to have fun with it eveyonce and a while. but about a week ago i noticed a slight erratic miss when accelerating under heavy load but went away if you let off some or dropped a gear. this problem seemed to just go away by its self till the other night.
So the other night me and my girlfriend went to town to eat ( about 30min drive) and after we ate i noticed that my lifters were a little rattly so i shut it off and checked the oil i was about a 1/4 of a quart low so i went to walmart just down the road wile i was on my way there, the miss came back slightly worse than before. I went in to walmart and got a quart of Lucas ( i usually add Lucas when i give it an oil change but didn't on the last change) the reason for adding the Lucas is because when i first put this motor in it would smoke slightly on start up (valve seals??)
So after topping off the oil I headed home with the miss not getting any worse until about 6 miles from home . being dark I could really do much i figured it was spark related so I limped it home were I checked for arcing with the hood up in the dark and didnt see any.
The next day i checked the cap and rotor and wires all seemed ok, the cap did look like it needed to be changed and there was some slight corrosion on one wire on the cap side i cleaned it the best i could . This did not help so i took the truck to town and tried to get A Rotor and Cap they waned 64 something for a cap and rotor so i said no, but i did get some ngk plugs and cam home and ordered the other things i needed from rock-auto should be here in a few days.
I went a head and changed to plugs they all looked good besides cylinder 2 witch had some oil on it. after changing the plugs and adding connection grease it ran quite a bit better so i figured it was just an fouled oil soaked plug but i took it down the road and it was smoking pretty bad on start up ran great to the floor in the high rpms but i still have a miss if i over shift it and floor it.
Anything i should check while i Waite on my other parts to come in??
thanks in advance ,,, william
