I'm really new to my Festiva ('89 L 4-Speed)... had her a day and a half now.
The instrument cluster is very dark, like maybe only bulb is working. How do I go about changing the little buggers? Can it be done by reaching up behind the dash or maybe pulling the cluster?
Can't find a Haynes or Chilton locally, except special order and the last special order took almost 2 months to arrive!
Not a serious issue since I don't have a big need to drive after dark, but it's annoying! The darned things are there and they supposed to =work=!
Appreciate any advice,
Amanda :? :?
Amanda :? :?
. But I did get the number for them, they are 73s... and the stock number for the backlight bulb is 158, but 194s work fine and are available in different colors... still have to wait till it gets dark enough outside to see if putting in the blue bulb worked though.
