doing my bearings and brakes , I seem to think that I have read somewhere to only do one side at a time, is this true ???? and if so why ???
wheel bearings and brakes
This is 'stone age' advice but I have never regretted abiding by that rule:
By only doing one side at a time (brakes, springs, shocks, you name it) you retain a complete and untouched other side to visually/physically refer to when re-assembly or other problems rear their ugly head.
And confusion happens all the time!
Not all hub-spindle things are created equal. In order to form a more perfect bearing preload the hub things are measured at the factory and the correct thickness sized bearing spacer is selected to insure this happens. This is why each hub needs to keep its original spacer. Evidently the bearings themselves are easier and cheaper to hold to a tighter tolerance as they are finish ground.
Depending on if they are OEM or aftewrmarket, but 28, 29, 31 and 32mm have been found.Originally posted by stonemaster View Postthanx again, what size socket for the axle nut ??? (of course i dont have the right size)'93 Blue 5spd 230K(down for clutch and overall maintanence)
^ yea if you go with a 30mm or 1 1/8" it should take care of it even if its a 282008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
:eeeeeek: Around here all the do it yourselfers use a hammer and a chisel :pOriginally posted by georgeb View PostMy 1 and 1/8 fits all 3 of my Festivas including the Aspire-swapped one.
One of them won at the casino and bought all top notch tools from Snap-on.
He uses an air compressor and air chisel
It gets really bad for those guys that live on the sand spit over on the coast
with ocean view in their face. They add a torch to their repertoire to cherry
red heat the victim before removal..pretty fancy stuff!! :pReflex paint by Langeman...Lifted...Tow Rig
I've only found 29mm and 30mm across my Festy fleet over 12 years.
I don't think you really want to torque it back together with an "almost fits" Imperial units socket, particularly a 12-point.88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
I use a 1 3/16 oil sending socket. I costs a bit less than the axle nut sockets at the auto parts store.
It depends on the condition of the grease seals and whether you can get them off without damaging them. I've learned to tap the inner seal out by sliding a screwdriver in from the other side.
Photos at www.photobucket.com/Festiva-frontwheelOriginal owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
