Do Festivas have a computer controlled rev limiter?
I've always been afraid to take mine over 6,000. What is the max red line?
Engine braking. I do it sometimes, but these engines don't really have enough compression to slow you down fast or completely. My question is how it affects fuel economy. It saves brake wear but what about gas mileage?
Since the throttle plate is closed and probably no more air flow than idle, does that mean it is only using as much fuel as idle speed? If i turn off ignition while slowing in gear, the engine sounds pretty much the same. And if I turn the ignition back on, there is no change- as long as my foot is off the gas pedal.
And- timing. I have not yet been able to time my car. Its been bugging me for over a year. I've removed and reinstalled my timing belt at least three times. I'm positive it's lined up. But I can never get the crank marks in the right place. So I time by driving it and adjusting the distributor.
I had the dizzy set where everything felt ok and I've been running midgrade gas- about 89 octane here. I've had a noise- like ratting, odd sort of noise- mostly when under large load like hill climbing in 4th or 5th gear. If I put in regular octane (87) on accident the noise seems louder and more common and I also notice a decrease in fuel economy.
Last week I filled up with premium (91 octane) and the rattly noise is gone. Period. I haven't noticed a gain in mileage, but with the disappearance of the noise and higher octane, I can assume my timing is not correct.
Also, since I've gone to premium, I've noticed a slight hesitation when accelerating hard in the higher gears.
Before anyone says it. I last did a tune up just over a year ago. The plug wires, cap, and rotor have less than 30,000 miles on them. I replaced the spark plugs with NGK V powers in January this year.
