Fuel pump and CEL
  • Fuel pump and CEL
    Anyone know off hand if a failing fuel pump would trigger a check engine light. Last night my car was surging and every time it surged the CEL would come on briefly. Nothing obvious after a quick look under the hood.
    No, none of my fuel pump failures threw a CEL.
    But, also none of them failed in the way you describe.
    They ran fine, then on the next start-up "no go".
    I'm thinking your issue could well be somewhere else.
      Mmm, drove it this morning and it ran perfectly, no surging, no CEL
        Its back, anyone have a clue ? See video below
          Ground the STI and see if it shows something.
            Could be the ECM relay. The computer keeps resetting maybe?
              I used my multimeter ( + cable on the STO pin of the self test output plug, - cable to ground ) and used a jumper to ground the self test input connector. I got a code of 9. Anyone know what 9 is ?
                CEL Code
                Hello Fresh, the 09 code is asking to have the coolant temperature sensor checked. Good luck.
                  Thanks, thats the one on the intake manifold right ?
                    You don't need a multimeter. The CEL blinks the code.
                      CEL Code
                      yes it is, i changed mine and improved the mpg's.
                        Oh yeah ? Just ground the STI plug ? Does that work on both KOEO & KOER tests ?
                          Wow, too cool !! Thats much easier Still getting a nine. Video below
                            Not familiar with the tests you mention above.
                              KOEO ( key on engine off ) KOER (key on engine running)
