ATF Consumption
  • ATF Consumption
    My bent, dead cyl, noisy wheel bearing and clunking CV joint '92 automatic DD has developed a problem. It was jumping in and out of first so I checked the level and it was dry. I just added a pint a month ago and it hasn't been leaking. Where is it going?
    Through your leaky vac diaphragm and into your intake.
    91GL BP/F3A with boost
      Wouldn't it be smoking?
        I think I found the prob. One of the cooling lines is cracked. I might have to lower the crossmember to get at the clamp because it's facing down.
          Make sure you replace both lines while you're down there! If one broke the other one will as soon as the first on is fixed I can promise you that
          No festiva for me ATM...
