Advance should increase with engine speed... base idle timing should be "0" +/-1. With vacuum present, you should see something like 14*, and it should be all in at just over 3000 with ~26*. You would only retard the timing at higher rpm if you were under boost, and that's just to help control pinging/pre-ignition. I'll grab one of my dizzys and double check the spring advance theory.
Disty Vacuum
^ that's if you want more out of the b3, on 89+ oct, you bump the timing to those numbers. Factory timing specs are as stated above. I honestly believe they left ALOT on the table when they put the b3 in production. The exhaust runner is a good example...Trees aren't kind to me...
OK so it should be using the EFI dizzy, not the carb unit.Trees aren't kind to me...
I'm running a b6d with carbs. No efi in my system. I went with the carb distributor because that's what I had. I'll keep looking into what formula works best. I did find this table for miata advance and since it's essentially the same motor, I figured I need to get it close.Originally posted by FestYboy View PostOK so it should be using the EFI dizzy, not the carb unit.
Wow, all in at 5500...
Yeah you need the carb dizzy then for the vac advance.Trees aren't kind to me...
That shouldn't be too difficult, I'll tear one apart in the afternoon.Trees aren't kind to me...
