I recently bought an 89 festiva. It is fuel injected. I eas told by the previous owner that it sat for a bit before I bought it and before its "time out" it was driven infrequently and not far. I paid a mechanic to put a new timing belt and water pump in it and it ran good for a few days albeit with lower than expected gas mileage around 24 mpg. Then it stalled while my wife was driving it and wouldn't start back up. A different mechanic replaced the fuel pump said it drove fine on the test ride and when we went to pick it up it wouldn't start. He then replaced the timing belt again (my wife didn't tell him about it already being replaced) and again it ran fine for a few days and crapped out. I just now replaced the spark plugs and made sure I had fuel and spark. If I try to start it it will start for a few seconds and stall then it will only sputter until it sits for awhile then it will start and stall again. Any suggestions you guys have would be great I'm a motorcycle mechanic not a car mechanic so I know how engines work but I'm new to cars so please keep that in mind when offering suggestions. Sorry for the long post and thanks for any help you can give.
Trying to get my "new" festiva to start
If it starts and runs for a few seconds, I'd check the VAF connection.
That is exactly what it will do if you loose the VAF connection or the air tub is not properly connected and you are getting unmeasured air in the engine.
That wasn't a long post.
See a Bobstad post for comparison.
Last edited by Pu241; 08-05-2012, 06:19 AM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Sounds exactly like what my cars doing. I replaced fuel pump filter broke the vaf nd had to replace. Changed all plugs plug wires cap nd rotor. Have good fuel pressure while it was sputtering nd dying. Swapped ignition switch. Ignition module was ok. Nvr checked the coil. It was 80 for a new one. Inside of the dizzy was clean. When ever it would sputter nd die it leaked oil. Recently saw it bubbling on the back side near the driver side. Thinking it has a vaccum leak thru the head nd manifold. Does urs leak oil?
Check the VAF connector and see if it has it's wire retainer still attached.
If wiggles or is loose you've probably found your issue.'93 Blue 5spd 230K(down for clutch and overall maintanence)
