I just pulled a BP manual flywheel today because the BP engine that i bought was from an auto. The flywheel i got does not fit, what did i do wrong??? I am using a manual festy 5-speed that i bought from stainless1911
BP Flywheel and Festy Manual Transmission
Well since you actually posted this in the right section (for once) ill give you some help
You need to keep the matching flywheel to the trans, if your using the stock E series trans, you use the stock E series flywheel on the BP
Ok, so i do not need the flywheel off of the BP??? But wont that throw the bearings out on the BP engine? or are they weighted appropiatly to prevent that?91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Adjustable VW MK2 front suspension and Aspire disc brakes
Aspire rear axle and drum swapped with adjustable KYB rear suspension
LOOKING FOR RUST FREE SHELL IN CALIFORNIA
All flywheels are balanced from factory, so use the stock flywheel and you'll be fine
ok, this is sounding better then. Will i need a different block plate then? Meaning currently the plate i have has the starter on the side while the tranny has the starter hole up top?91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Yes use the stock plate, but I can't remember if you gotta modify it slightly for the BP or not.... Mock it up and check it out to be certain
I think using a stock E series on the BP requires a bit of grinding to make the axle geometry work, I believe you use the plate as a template, not sure though.Owner of:
In progress:
ok, well im gonna head back up to the j.y. on monday to get that stuff then =/91' Festiva GL Auto EFI--- BP swapped, G-Series swap in the works.
Yes you are correct, since the stock axles do not use an intermediate shaft, the inner pass. side CV joint is (obviously) larger in diameter then an int. shaft that the BP came with from factory, so clearancing is requiredOriginally posted by kellen302 View PostI think using a stock E series on the BP requires a bit of grinding to make the axle geometry work, I believe you use the plate as a template, not sure though.
