Well I just purchased this speedo on eBay a couple weeks ago and I didn't notice it until I went to install it yesterday, but it's got a broken base for the Speedo cable as well as one of the pieces where the electrical plug connects. I'm trying to figure out what my next move should be. I tried electrical taping the the speedo cable to the cluster, but it didn't hold. I was thinking about trying to dremel out the one from my stock cluster and plastic welding it onto the new one. I don't believe there is anything I can do with the seller as I already left positive feedback when the cluster arrived. It said it came from a running car so I just figure it was good. After further inspection it looks like the cluster was just ripped out of the dash without undoing any of the connections.
I should have inspected it better before leaving feedback. Any thought on how to fix this?
Also when I was testing it out after trying to install it a few times the RPMs were working fine (That connector was the one with the broken center piece, but it held it just fine) The gas gauge on the other hand didn't seem to be working. It was resting in the center when the car was off, but when I turned it on it shot up to like past full and I know that I had under a 4th a tank when I swapped clusters. Do I need to swap the clusters on a full tank?
I have a feeling I just had a 75 dollar lesson!
Stock cluster.
Tachometer Cluster with Broken Speedo Base.
I should have inspected it better before leaving feedback. Any thought on how to fix this?Also when I was testing it out after trying to install it a few times the RPMs were working fine (That connector was the one with the broken center piece, but it held it just fine) The gas gauge on the other hand didn't seem to be working. It was resting in the center when the car was off, but when I turned it on it shot up to like past full and I know that I had under a 4th a tank when I swapped clusters. Do I need to swap the clusters on a full tank?
Stock cluster.
