My festy starts fine but under load or high rpm it misfires at the coil.. You can see the spark jumping at the coil from the coil wire to the coil uuggh its driving me crazy
coil help
the coil tower insulation has broken down and there's likely micro cracks on the tower that are carbon filled. if that's the case, you need to replace the coil. i recomend the Accel super stock unit. i use several of them and it's easy to retrofit carby and EFI cars alike.Trees aren't kind to me...
